biggest cams with no ptv issues
Old Feb 12, 2008 | 10:20 AM
THEBRAD's Avatar
Default biggest cams with no ptv issues
what r the bigest cams (highest lift, most duration on a 112 lsa) u guys have stuck in ur f bodies with 241 heads without cutting the pistons or addind thicker gaskets or any of that crap just stickin it in and going. these can be street cars or drag cars just interested in what the motors can take before there are clearence issues
Old Feb 12, 2008 | 10:24 AM
landonew's Avatar
+1, would also like to know this. W/ AFR 205s assuming .03 cometic.
Old Feb 12, 2008 | 10:45 AM
sciff5's Avatar
TREX and MS4 are good examples. Chumma created a custom cam for a guy on here that fit without flycutting and its bigger than both the Ms4 or the TREX. Its like 245/250.
Old Feb 12, 2008 | 10:46 AM
TheLS1Kid's Avatar
+1 for T-rex and MS4.
If I'm not mistaking I think they were both designed to be used with stock heads with no flycutting.
Old Feb 12, 2008 | 11:14 AM
Camaro396's Avatar
I have 241s with the MS4
Old Feb 12, 2008 | 12:34 PM
ws6_bandit's Avatar
G5X4 is up there.. it will fit without flycutting.
Old Feb 12, 2008 | 01:35 PM
moeZ28's Avatar
TREX V2 is about as big as you can go with stock heads, and have an effective power band. TREX was designed to be used with stock heads and does very well, but its also excellent with ported heads if you ever decide to do a head swap.
Old Feb 12, 2008 | 01:41 PM
Rob@EFIAlchemy's Avatar
LS1Tech Sponsor
im running a 234/240 .627 .641 112lsa with 853 heads that were milled .010 for trueing with no flycutting
Old Feb 12, 2008 | 02:26 PM
THEBRAD's Avatar
that, is a good amount of lift. thanks guys
Old Feb 12, 2008 | 02:55 PM
CobraB8_ZO6's Avatar
Will the T-Rex work with stock 243 heads?
Old Feb 12, 2008 | 08:30 PM
418redz28's Avatar
i dont think so i think that the valves are just a lil bigger then the 241 heads.
Old Feb 12, 2008 | 11:35 PM
BigKap94z's Avatar
It should fit the stock unmilled 243's just the same as 853's and 241s. The valve size is the same, chamber size is smaller but that won't affect the PtoV clearance. Pretty much all these cams listed clear, but most don't clear by safe margins. Honestly I don't understand the big cam craze around here.
Old Feb 13, 2008 | 06:04 PM
THEBRAD's Avatar
i never said i wanted one and neither did anyone else on this thread i simply stated in the first post i wanted to know just to know, for the technical stand point.
Old Feb 13, 2008 | 06:36 PM
sevanseriesta's Avatar
244/248 .612/.615 @ 114+2 stock 346 although this is with 317 heads, I am in the process of changing heads though
Old Feb 13, 2008 | 09:47 PM
santiago's Avatar
yes it will i ran this set up hard till i bought my 408.
Old Feb 14, 2008 | 10:16 AM
The Dragon's Avatar
Cool
Originally Posted by BigKap94z
. . . I don't understand the big cam craze around here.
For those with confusion akin to BigKap94z here is an answer: then you too can walk away from a 510 hp 2007 Lamborghini Gallardo Spyder on the highway
My very good friend bought one new 4 months ago and I walk him N A S T Y every week we roll (on motor BTW)
With the proper combination of parts and proper driving, a good big-cam/heads set-up can be devastating
Old Jul 19, 2008 | 12:37 AM
tnmotown's Avatar
i know this is kinda a old topic but, will the G5x4 clear stock ls6 heads?
Old Jul 19, 2008 | 04:14 AM
LS1C5Vette's Avatar
Yes (unmilled heads stock mls gasket)
Old Jul 19, 2008 | 11:49 AM
MasterMindMotorsport's Avatar
I have ran an MS4 in a stock long block with 241's and 243's and on a stock 07 LS2 also with 243's with no issues to date
