5.3 heads
Old Feb 12, 2008 | 05:07 PM
Daryn's Avatar
Formerly darynC-10/23/10
Default 5.3 heads
i have a t-rex with stock (ported) 853's, would switching to a set of 5.3 hand ported heads help me any?... , would it up my compression much?
Old Feb 12, 2008 | 05:34 PM
mchdg86's Avatar
It will up the compression if your current heads aren't milled, but I can't say if they will give you any power or not. You will most likely have to flycut the pistons with a t-rex.
Old Feb 12, 2008 | 05:50 PM
Daryn's Avatar
are the rocker arm stands the exact same as the ls1/6 heads?.. will i have to run a different pushrod or anythign like that'??....i have crane duals with the machines seats ect.
Old Feb 12, 2008 | 06:05 PM
mchdg86's Avatar
Yes you can reuse your rocker arm stands. With the stock gaksket thickness and unmilled heads you can use the stock length pushrods.
Old Feb 12, 2008 | 07:16 PM
2000_SS's Avatar
you're going to have to do some serious fly cutting with that cam, and 5.3 heads WILL up the compression to ~11:1. read about PRC's 5.3's on TSP's website....
