Oil pump o rings?
But there want a gasket where the pump met the block.. Is this suppose to be like this?
And make sure you center the pump with feeler gauges as you are bolting it down. Otherwise you will get glitter in your oil. Because the pump will be grinding the **** out of itself. Trust me I know. doh!
Speaking from experience.... you cannot reuse the o-ring
- Colby
