what size dowel
Old Feb 15, 2008 | 08:25 AM
noxiouSS's Avatar
Default what size dowel
For a cam swap to hold the lifters up? how well does it work? Any tricks to it?
Thanks
Old Feb 15, 2008 | 08:48 AM
jmm98LS1's Avatar
5/16" if memory serves.....
Old Feb 15, 2008 | 10:07 AM
Randy WS6's Avatar
I make mine out of 5/16" metal rods and ground a flat spot down the intier length of the rod's pass by the lifters then twist them to lock them down . Cut them around 22" long and if you have access to a welder you can weld you a (T) on the end to help turn and remove them, but its not a must.
Old Feb 15, 2008 | 10:20 AM
Dipstick's Avatar
5/16" wooden dowels from Home Depot worked for me. I had some steel ones, but they wouldn't go all the way in.
