Cam for stock heads
The car has an LS6 intake, LT headers, and is an M6.
I have already went out and bought a set of Patriot Gold springs to go onthe heads.
Curious of what cam specs stock heads can handle.
Any and all input is appreciated.
Comp Cam lobes
Intake XFI lobe # 3016
Exhaust XE-R lobe # 3725
LSA 111
ICL 109
In a nutshell, running a big cam for the sake of having a big cam just doesn't make sense. You will likely get similar performance from a slightly smaller cam and not lose any of the benefit. If you insist on running a cam that large, at least measure, rather than take someone's word it will fit. Too many variables to leave it to chance.
. A set of stock 241s is worth what, $200? That's about what gaskets and bolts cost to check PTVC so really it's just a toss up. I'm a risk taker. I say go with the Trex if you want a proven, mean sounding cam that you can rev the hell out of. That's what i was orgionally going to go with.
