help? how to check engine compression ?
Old Feb 15, 2008 | 08:32 PM
mike06tork's Avatar
Default help? how to check engine compression ?
anybody knows how to check the engine compression im try'n to check what compression will this engine combo will be at :
6.0 block with 4.000 std. bore
wiseco pistons with -11cc 4.000 bore
3.622 oem crank
6.0 317 heads oem not ported at all 71.2cc
with oem 6.0l head gaskets
scat I beam rods 6.125
so if anybody can check please if any body knows im trying to get the compression at 8.8:1 to 9.4 but i want 9to1 compression thanks for the help.
Old Feb 15, 2008 | 10:12 PM
mike06tork's Avatar
anybody knows?
Old Feb 15, 2008 | 10:48 PM
Z28Fistergod's Avatar
http://www.c5frc.com/calculators/Com...Calculator.htm
Old Feb 15, 2008 | 11:19 PM
mike06tork's Avatar
anybody knows how thick is the oem 6.0l head gasket thickness ?
Old Feb 16, 2008 | 11:58 AM
itsjustaSB's Avatar
i preety sure its a compresed thickness is .057
