Oil EVERYWHERE. Need a li'l help please :)
Although LS1 is a mild amusement loooooooaded with amusing people, LS1Tech is a true TECHNICAL site which I respect greatly (therefore I would not like to take up any more band width over this flame).
If you would like, I'll forward you the e-mail(s) that I have in my inbox with E (LS1 Administrator).
All the necessary information is in them and you are free to post it publicly wherever you like if you so desire (or feel the need to do so).
Again . . . thanks for the helpful reply
If your rings are busted, you'd get excessive crankcase pressure. This means when you pull the oil filler cap with the car running, you'd have smoke coming out. This also means you'd be pushing tons of pressure out your PCV which would take a LOT of oil with it.
Judging by your symptoms, it's pretty obvious your rings are toasted. Or you have a hole in a piston
Dope
Dope
Thanks for all of the input fellas
