Any tricks to get the oil pan to drop?
Old Feb 17, 2008 | 01:50 AM
noxiouSS's Avatar
Default Any tricks to get the oil pan to drop?
Changing the oil pump and i need to drop the pan like 1/2 an inch to get the pick tube out. I got 8 out of the 10 bolts loose put im having trouble reaching the ones under the k-member. any tips?
Old Feb 17, 2008 | 02:10 AM
BlackZ28629's Avatar
take out the bottom two tranny bolts
Old Feb 17, 2008 | 10:38 AM
massls1guy's Avatar
I used a ratcheting open end gear wrench on those. You can get them by reaching up from the back over the K member.
