Cam choice...
Old Feb 17, 2008 | 08:36 AM
73brewstersd's Avatar
Default Cam choice...
I currently have a lunati cam. It's something like a 222/230 114LSA. The idle is "alright", but I really love a choppy sound. I have an M6, full exhaust, and Intake. I'd just like some advice on a complete choppy cam install..
1.) What cam will give me great sound. I'm not really worried too much about HP numbers. I never go to the track, just the local cruises.
2.) What springs for the ^^^ cam?
Thanks for the help!!
Old Feb 17, 2008 | 09:32 AM
Patrick G's Avatar
LS1 Tech Administrator
You'll want a little more overlap and a low idle speed to give you the chop you want. Your current cam has -3 degrees of overlap at .050". Around 6 degree of overlap coupled with the stock idle speed of 800 rpm will chop pretty hard while still giving you good street manners.
A 230/230 112LSA cam will give you 6 degrees of overlap.
A 226/226 110LSA cam will also give you 6 degrees of overlap.
The springs needed depends on the lobes you choose. Run XE high lift lobes (.570ish lift) and you can run affordable 918 beehive springs. Run XE-R or XFI lobes (.590ish or .610ish) and you will need to run dual valve springs.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Feb 17, 2008 | 09:47 AM
How do you lower the idle? Mine just stock 1k..Thanks for that info above!!
Old Feb 17, 2008 | 02:06 PM
Patrick G's Avatar
Stock 98-02 F-bodies and Corvettes with 6 speeds idle at 800 rpm. A cam of the size I mentioned will chop pretty hard at 800 rpm.
__________________
Old Feb 17, 2008 | 02:11 PM
02T/A-WS6's Avatar
There should be a little screw on the left side of your throttle body under the throttle cable. Back that down and then it will lower your idle.
