pickin heads
Old Feb 18, 2008 | 11:20 AM
Rob@EFIAlchemy's Avatar
LS1Tech Sponsor
Default pickin heads
ok so i think im gonna buy a set of heads for my cam but im not real sure what will be a good match, my cam is a 234 240 .627 .641 112lsa.
Old Feb 18, 2008 | 11:25 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Given your exhaust lobe selection you really don't have a ton of p/v clearance on the exhaust side. You definately want to keep that in mind when selecting your cylinder head. We sell alot of our PRC stage 2.5 5.3l heads for camshafts that size, or possibly even the PRC Street LS6 heads. Either combo should add approx. 45rwhp & is in stock & ready to ship! Here's the link for specs:
http://www.texas-speed.com/shop/item...id=84&catid=40
http://www.texas-speed.com/shop/item...d=649&catid=40
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Feb 18, 2008 | 04:25 PM
HEMIETR's Avatar
TFS heads will give you the most PTV clearence and more HP than above. It will cost you more too.
Old Feb 18, 2008 | 04:29 PM
mesospeedy's Avatar
If you can afford TFS or ETPerformance, go that route. If not TEA has some great heads that are a little more affordable.
Old Feb 18, 2008 | 04:44 PM
ThunderStruk's Avatar
TFS heads will allow for a little more piston to valve clearance and make very nice horsepower. They would work really nice with the split you have in your camshaft.
John
Old Feb 18, 2008 | 07:30 PM
LS1Tech Sponsor
thanks guys
