pushrods and rocker (ratio?)
thanks alot
stock ratio is 1.7
moving up to 1.8s will gain some power, but require better springs. and if you do a cam down the road will limit choices, as most cams don't allow the use of higher ratio rockers due to the aggressive lobes
