Best block's for sleeving?
Old Feb 25, 2008 | 06:56 PM
WickEdSix98's Avatar
Default Best block's for sleeving?
I've been looking for a stock LS1 aluminum block to have re-sleeved so I can build an all bore engine. What year models are good and which are bad? It will be NA with some 11* RHS heads, solid roller, and around 14:1 compression.
Old Feb 25, 2008 | 07:01 PM
JMBLOWNWS6's Avatar
For the price you are going to pay to have a block re sleeved you might as well get an ls2.ls3 or ls7
Old Feb 25, 2008 | 07:35 PM
Gannet's Avatar
A sleeved block is not the same as a LS2/3/7. It has different strengths and weaknesses. Certainly it is not a way to save money.
This thread should be of interest.
Old Feb 25, 2008 | 08:28 PM
DONAIMIAN's Avatar
When sleeving, they don't like to use the ls6 block because the "windows" give up strength. Not sure about the early blocks 97-98. I would just try to get a 99+ LS1 block and you should be fine.
