Ms3 Cam?
Old Feb 25, 2008 | 07:35 PM
Jsak's Avatar
Default Ms3 Cam?
Would an ms3 cam work well with a 3400 stall?
Old Feb 25, 2008 | 09:03 PM
TXZ28LS1's Avatar
it should be fine. but you would maybe want a bigger stall to really compliement that cam.
Old Feb 25, 2008 | 09:48 PM
chewy99ws6's Avatar
Yes it will work, I run the MS3 and a 3400 fuddle stall, if you plan on going to the track alot I would suggest bigger but since mine is DD 3400 was more suited for what I wanted.
Old Feb 25, 2008 | 09:50 PM
greinder03's Avatar
4000 or higher
go big or go HOME
Old Feb 25, 2008 | 11:49 PM
Camaro396's Avatar
Originally Posted by greinder03
4000 or higher
go big or go HOME
Im with this guy.
Old Feb 26, 2008 | 12:39 AM
99FBODY's Avatar
i have the ms3 with a 3500 stall and im going up a 4000 stall that i have.
Old Feb 26, 2008 | 06:03 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I'm going with a TH350 with a 3500 behind my MS3. The 4.11 gears should help a little
