ls1 harness power a ls2????
Old Feb 26, 2008 | 05:49 PM
1fastmofo's Avatar
Default ls1 harness power a ls2????
i have a ls1 in my car and im considering going to a ls2 will the ls1 harness work properly for the ls2? what about the ecm? thanks cory
Old Feb 26, 2008 | 06:21 PM
RE AND CHERYL's Avatar
I know the PCM will not because the two engines have different reluctor wheels on the crank. I'm not sure about the harness bacause I thought the LS2 had an electronic T/B.
Re'
Old Feb 26, 2008 | 07:07 PM
HAZ-Matt's Avatar
You could use an LS1 style reluctor and throw a cable TB on it, afaik. If you buy an LS2 based motor from various sponsors you can specify which wheel they put on.
Old Feb 27, 2008 | 01:04 AM
1fastmofo's Avatar
ok well the cable tb is a must anyway because my car is fd3s
Old Feb 27, 2008 | 05:22 AM
bluecamaroz28's Avatar
You will need cam sensor and knock sensor harness extensions to run an LS2 off an LS1 harness. Most sponsers have them.
There is a sticky about swapping LS2.
Old Feb 27, 2008 | 01:28 PM
socal's Avatar
an 05 gto has an ls2 w a 24 time reluctor, while an 06 has a 54 time and the tb doesn't matter but the knock sensor are outside on the side of the block, and the cam pick up is on the cam sprocket/front cover, thats about all other then the cid.
so yes with the proper reluctor wheel the stock harnness and ecm will work with minor modification (wire rerouting and extention) SDPC offers an ls1 to ls2 convertion kit look into that
