6.0L upgrade help...
Old Feb 27, 2008 | 09:49 PM
flywheel's Avatar
Wink 6.0L upgrade help...
I have an lq4/4l80e combo to go into my 71 chevelle and have been reading post after post about these ls1 type motors. Can someone tell me how this lq4 motor will respond too cams/intakes? What will these heads handle? Intake handle? What kind of HP/torq #'s should I expect? What's needed to get it up to 450HP range?
Thanks for the input!
Rick
Old Feb 27, 2008 | 11:48 PM
m8w6r77's Avatar
the heads flow just as good as the ls6 heads. the comp ratio is 9.4 to 1. not sure which year 6.0 you have. i have the 01. it has the aluminum heads. are you wanting rwhp? the truck intake is hangs right in there some of the other intakes. but starts to drop at 5800 rpms if i remember right.
Old Mar 1, 2008 | 09:46 AM
flywheel's Avatar
Mine is an 03 model. What is needed to get what kind of HP? I guess 450rwhp would be alot, maybe, 450 engine HP?
Thanks,
Rick
Old Mar 1, 2008 | 10:07 AM
o2camaross's Avatar
LS6 intake for sure. Do you want a lopey cam? I have a 71 chevelle myself, but im going with a 502, but anyway. You night wanna try to make a little more power since you are going to be using that 4L80, bc they eat more power than a 4L60.
Old Mar 1, 2008 | 10:58 PM
flywheel's Avatar
of course it has to have a lopey cam, afterall it's a chevelle. It has to sound the part... I was thinking something like .224/.230 duration, w/ .550/.560 lift on 112 sep.
Rick
Old Mar 2, 2008 | 01:36 PM
flywheel's Avatar
anymore help?
Rick
Old Mar 2, 2008 | 01:49 PM
litle88's Avatar
Rick
If you wanna stay in that duration, look at the GMPP "ASA" cam it is a nice lopey, under the curve, and good torque off the line!
http://www.sdparts.com/product/12480...rCamshaft.aspx
here is a lil info I saw on the November issue of HOTROD magazine, they used a hotcam and as you can see it hangs right in there with the best of them and are easy on the springs!!!...
hope it helps alil bit, goodluck
[img][img]
[img][img]
Old Mar 3, 2008 | 07:59 AM
flywheel's Avatar
Thanks litl88, interesting read.
The ASA cam is on a 110 lsa, is that going to work with the computer,etc.? This ls1 stuff is kinda confusing compared to BB stuff...
As many have said it's in the combination of components you have. Just want to make sure to get the best combo...
Rick
Old Mar 3, 2008 | 05:12 PM
litle88's Avatar
yup, it will! just need a tuner!
Old Mar 3, 2008 | 10:22 PM
flywheel's Avatar
What exactly is a "tuner"... I hear this alot... Is it one of the hand held tools or someone with more specialized equipment? Sorry for sounding dumb, Im from the "carbed,BB days"
Thanks alot,
Rick
Old Mar 3, 2008 | 10:32 PM
NemeSS's Avatar
Thanks alot,
Rick
recalibration of the pcm fuel and ignition maps, to complement the new
upgraded parts.
Old Mar 4, 2008 | 01:01 AM
litle88's Avatar
Thanks alot,
Rick
Im sorry a tuner is a handheld, but I would do some research and find a speedshop that DYNO tune Lsx cars or trucks in your area, for instance I get my car TUNED at straightline who happen to be a sponsor and Mike will Tune my whole PCM or computer cell by cell ie WOT runs, part throttle, adjust timing, AFR, throughout the whole RPM range. Hope that helps.
Old Mar 4, 2008 | 07:56 AM
flywheel's Avatar
Thanks guys, that helps make it clearer....
Using an ls6 intake, and a mild .224/230 cam, full headers,and no cats on my chevelle, what hp/torq range would the lq4 be in? 350-375hp maybe???? Thanks..
Rick
Old Mar 4, 2008 | 04:49 PM
litle88's Avatar
Rick
With a lift of at least 224In/230Ex and a lift of .550 and a set of trickflow's you'll be in the mid 420's or a little less with an automatic. But with an LQ4 you can spray the snot off that thing!!!
Goodluck
Zeke
Old Mar 4, 2008 | 06:43 PM
flywheel's Avatar
NOS, that's a thought... not tried that.....
Rick
