Where do I go from here?!?!
Old Feb 29, 2008 | 01:58 AM
stealthy_2005's Avatar
Exclamation Where do I go from here?!?!
Alright, I now have a SS3600, BMR subframe connectors, ZR1 17x9.5 with 255/40/17 fronts and 17x11 with 315/35/17 rears, 3.73 gears, SLP Flowpac, Pacesetter LTs, and the TSP true duals... Is cam only a good direction to go? Or what do I need to do?!?! I know a torque arm should be coming up soon... But now I'm lost and need some good advice?
Old Feb 29, 2008 | 02:08 AM
discostu's Avatar
personally i would finish the suspension. I was always told start from the back forward. so stronger rear end then trans and driveshaft and so forth
Old Feb 29, 2008 | 08:26 AM
fast377's Avatar
Maybe look into a 12bolt or 9"? Heads and cam would be next...or maybe nitrous.
Old Feb 29, 2008 | 09:24 AM
00_transam_vert's Avatar
Yeah i would deffinantly go with a Cam. You've got all the right supporting Mods!
Old Feb 29, 2008 | 11:32 AM
No way, now how... No nitrous EVER... I like my car too much. And about the rear end... With an auto I hear a 12 bolt is better than a 9"?
Old Feb 29, 2008 | 02:09 PM
Fast Toys Performance Parts's Avatar
DEFINITELY. Your stock 10 bolt is likely to blow up if you plan to go to the drag strip. Get a nice Moser 12 bolt or 9" and then you don't have to worry. Check out our catalog for details.
By Brett Foote | 2026-06-04 05:00:17
