After Cam Swap Problems...
Old Mar 5, 2008 | 06:54 PM
slaptastic's Avatar
Originally Posted by trembles
Did You Change Valve Seals ? If You Did Thats The First Thing I Would Check To Make Sure They Are All Seated
Fixed that yesterday. Had popped my valve cover gasket out a bit. Haven't seen any smoke yet, although it was pouring out for the past 24 hours.
Need to pull the head and get a broken bolt machined out. Then after that the tune will come.
