Spark plug thread
Old Mar 5, 2008 | 01:08 AM
LS1on22s's Avatar
Default Spark plug thread
Hi guys, when i was attempting to put my sparkplug in i guess i messed up just the first couple threads, does this mean i have to take the whole head off? or can i just chase it with a tap? i really dont have the time/money to do the head
Old Mar 5, 2008 | 01:34 AM
Quickshift_C5's Avatar
If it's only the first couple threads and you are CONFIDENT in using a tap, I wouldn't think it a bad thing to just do it yourself. Just be CAREFUL and work it in very slowly and back out. Take your time.
Maybe some other people who have done the same thing could recommend something else though. In the end, it might be wiser to take it somewhere.
Also, how did you do this? Were you attempting to thread the plugs right away with the ratchet? Be sure to thread them as far as you can by hand, until you can't possibly go any further. THEN, use a tool for the extra force. If you do it by hand, the chances of actually crossthreading it are very very slim.
Old Mar 5, 2008 | 09:40 AM
Jon@WAR's Avatar
If you are going to use a tap, be extremely careful to start it straight, or you could potentially cause a larger problem. Coating the tap with some grease will help to retain any shavings on the tap also. Before you attempt to install the spark plug, inspect the threads on it to make sure it isn't the cause of your problem. I've run across plugs where the ground strap sticks out too far where it's attached to the plug, causing the plug to start crooked.
Old Mar 5, 2008 | 09:45 AM
Schwanke Engines's Avatar
LS1TECH Sponsor
Grease and a vaccum will go a long way for doing quick repairs.
Old Mar 5, 2008 | 10:26 AM
LS1on22s's Avatar
does anyone know the pitch of the tap i need? i belive its 14mm but what pitch
Old Mar 5, 2008 | 11:04 AM
sroach20's Avatar
http://www.kd-tools.com/3545.htm
Old Mar 5, 2008 | 11:09 AM
LS1on22s's Avatar
^^ that looks like it might work, anyone ever used it? and i can keep my head on for that right? im afraid to see how much thats going to be
Old Mar 5, 2008 | 11:17 AM
sroach20's Avatar
i used it on a truck i had and it saved my butt. never had to use it on the camaro.
Old Mar 5, 2008 | 12:30 PM
LS1on22s's Avatar
anyone know the price on these
Old Mar 5, 2008 | 12:39 PM
sroach20's Avatar
they are like $40. i borrowed it from a buddy.
