Solid roller question.
Old Mar 5, 2008 | 08:05 AM
Boosted1320's Avatar
Default Solid roller question.
Can you use the stock rockers or do you need adjustable ones? Also can you just put solid rollers in with a cam made for hyd ones? Im guessing you need a solid cam? Just curious though.
Old Mar 5, 2008 | 08:08 AM
KCFormula's Avatar
You have to use adj. rockers. Putting solid lifters in on a cam made for hyd. lifters will just wear out the cam. All the solid roller cams I have seen have a stronger billet core.
Old Mar 5, 2008 | 10:47 AM
I kinda figured that, but just out of chance i had to ask. Thanks.
