Can you re-use ARP head studs?
Old Jul 21, 2003 | 12:13 AM
JimMueller's Avatar
Default Can you re-use ARP head studs?
How many times can you torque an ARP head stud before it's wise to replace them? Had one snap yesterday and we were told that ARP changed their design recently (something like a tapered end..?). The block was covered under warranty for a previous issue, but it doesn't appear the new style studs were used during the rebuild.
Just curious if they fatigue. The stud snapped right at the top of the threads. They were able to get it out, but they're all getting replaced. Another set of 422 head gaskets down the drain too.
Old Jul 21, 2003 | 12:49 AM
highgear's Avatar
Default Re: Can you re-use ARP head studs?
They used to claim you could use them up ten times on a T/F motor.
However, if I was using them on a LS1 motor, I would check with ARP.
Studs are usually put in "wrist tight". If it could not be removed with an extractor; may have been installed wrong.
Old Jul 21, 2003 | 11:23 AM
10secondZ's Avatar
Jim,
What is this talk about a 422??!!...I need a ride man..now now now! lol...I was told ARP had a new design too...Might want to just get a new set..updated or not if they are new they should hold,
Carter
Old Jul 21, 2003 | 02:47 PM
2001CamaroGuy's Avatar
When did this "new" design come in because I did head studs this last January (head/cam install)?
Old Jul 21, 2003 | 07:05 PM
JimMueller's Avatar
Hey Carter...
No such luck, it's not my engine
