questions?.. on what to do about a cam
Old Mar 9, 2008 | 09:34 PM
cya-svt706's Avatar
Default questions?.. on what to do about a cam
i got a set of 5.3 ported heads to go on my car , what cam is good to go with? am i gona have to worry bout clearnce? what lift and duration would be good to go with ? thanks
stock pistons.
Old Mar 10, 2008 | 10:21 AM
Vrbas's Avatar
I went w/ a 228/232 w/ just under .600 lift on a 112 w/ a set of LS6 style heads. It works great, though for me the powerband comes slightly late in the RPM range (>3.5k RPMs). Overall though, i'm really happy w/ the cam. In the distant future, i might look at a 224.
Clearance shouldn't be an issue unless you're looking late 30's range i would assume. Lift should hover around .600
Old Mar 10, 2008 | 10:51 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
We do alot of the Torquer 3 camshafts with our PRC 5.3l stage 2.5 cnc heads. You should see about 50rwhp gains from the Torquer camshaft over a stock cam!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Mar 10, 2008 | 04:40 PM
cya-svt706's Avatar
thanks for the help!!
Old Mar 10, 2008 | 04:50 PM
cya-svt706's Avatar
thanks for the help
Old Mar 10, 2008 | 07:16 PM
SOMbitch's Avatar
Milling and gasket thickness will also affect PTV clearance and should be considered too.
Old Mar 10, 2008 | 07:42 PM
SLP Firehawk's Avatar
i saw almost 45 rwhp from a torquer v2 only swap
Old Mar 10, 2008 | 09:03 PM
cya-svt706's Avatar
awesome i think im going to go with the v3 thanks for all the info..
 Michael S. Palmer
cya-svt706's Avatar
what head gasket thickness should i run?
Old Mar 11, 2008 | 07:47 AM
Vrbas's Avatar
Stock replacement?
