268 hp ????????????
Old Mar 10, 2008 | 09:08 PM
  #41
Puppet_Master's Avatar
Don't you love how people keep chiming in saying about how much power they got lol? That'd probably start to **** me off. But anyways. I think the compression check will really narrow down what's going on. Hopefully no seals are leaking, are you getting a lot of smoke from you're exhaust or are you burning oil?
Old Mar 10, 2008 | 09:10 PM
  #42
therobman's Avatar
nope no smoke even if it was a stall issue y would the injectors be maxed out?
  #43
SLP Firehawk's Avatar
no offense but that dyno graph is really messed up it looks like u have a 4800 stall like the one person mentioned i have the same cam although my car is an M6 but the hp on my graph doesn't even fall off at red line it makes power past 6500 with stock 28lb injectors ur graph is all jagged at the end of the run unless thats because he shut down the run... i think he needs to tune it before he runs it at WOT
Old Mar 10, 2008 | 09:26 PM
  #44
therobman's Avatar
yea thats where he shut down the run
Old Mar 10, 2008 | 10:24 PM
  #45
StreetLethal01's Avatar
Don't be retarted, We are chiming in to show what similar setups are putting down not to show off numbers.
Old Mar 10, 2008 | 11:02 PM
  #46
Well there's obviously something wrong with his power output... So I don't know how many people have to say how much power they got. It'd be different if he was 300+.
Old Mar 10, 2008 | 11:08 PM
  #47
therobman's Avatar
he also said with the new injectors it should put around 315 on a mustang dyno so thats like 330 335 on a dyno jet and he would do a quarter mile run to see how fast it was cause he thinks my stalls eating alot of the power idk i think it should be higher plus i would think the injectors i have now should be enough stall or not
Old Mar 10, 2008 | 11:22 PM
  #48
mattraypharbor's Avatar
+1...
Old Mar 10, 2008 | 11:23 PM
  #49
JUST giving him a comparson because that weilds good information.
  #50
Asmodeus's Avatar
Your stall is eating a lot of power because there's something wrong with it. It should not jump to 5500 and hold if it's a 3500 stall. And just because the injectors are high on the IDC, it doesn't mean they're maxxed and you need bigger injectors. If you are seeing a pressure drop at the rail under WOT, you're not getting enough fuel to maintain a good A/F ratio and your O2's are asking the computer for more fuel. So the computer tells the injectors to stay open longer. It can also be a pressure problem (injectors won't flow as much fuel at a lower pressure). In which case your fuel pump and / or wiring harness can be the problem.
Old Mar 10, 2008 | 11:24 PM
  #51
seems i missed this post, at least im not the only one who think so!
Old Mar 10, 2008 | 11:25 PM
  #52
He has a vid and it does go past 6k-.5k and shifts! send this guy the vid you sent me bro.
Old Mar 10, 2008 | 11:29 PM
  #53
therobman's Avatar
that was just to show the stall that was before the cam and headers install its posted on the page back
Old Mar 10, 2008 | 11:32 PM
  #54
therobman's Avatar
http://tinypic.com/player.php?v=14vk7sw&s=3
here it is its BEFORE the cam and headers swap driving around town before lock up its at 32-3500 and i can footbreak it to 3300 before spinning them the video is when i get on it
Old Mar 10, 2008 | 11:34 PM
  #55
therobman's Avatar
my fuel filter was changed about 10,000 miles ago and then the car sat for 8 month with the same gas in it as i swapped my motor could that maybe be why
Old Mar 10, 2008 | 11:40 PM
  #56
LS1Silverado05's Avatar
Any chance that the Dyno is just way off?? Sometimes dyno's dont tell you good things, even though it runs good. How does it run? For instance, with my mods in sig, I was only able to Muster 340 on a Mustang when I was 3600 A4, and I was like, damn thats low....But later a friend with a fully built H/C 6.0 put down 403 it made me feel better.
My point is, even once you get the car dialed in....dont be over concerned with the Dyno number, ya know?
Old Mar 10, 2008 | 11:42 PM
  #57
1994Z28Lt1's Avatar
um have you checked your fuel pressure, i cant see how your injectors could be maxxed out unless you are running completely pig rich or you were down on fuel pressure
Old Mar 10, 2008 | 11:43 PM
  #58
therobman's Avatar
yea he said hed do a quarter mile run after its all tuned up and see if the numbers lie
Old Mar 10, 2008 | 11:45 PM
  #59
How does it feel?...Does it seem to run strong or pull hard, or does it run like crap? If those numbers are real then it should "feel" like ****. If not, maybe its like I suggested, and its a hateful dyno?..
Old Mar 10, 2008 | 11:46 PM
  #60
therobman's Avatar
no i havent checked my fuel pressure and i dont know if i was running rich or not i wasent there durning the run im deff going to talk to him about it tomorrow
