Smaller pushrods with milled heads/thinner gaskets?
Old Mar 12, 2008 | 04:04 AM
PREDATOR-Z's Avatar
I would have used 7.400 push rods for a quieter valvetrain, the 7.350s might be a bit loud.
The rest is good, gap the plugs at .040
Old Mar 12, 2008 | 09:12 AM
04gtod's Avatar
You are still guessing on the pushrod length. Why not get an adjustable pushrod and measure the correct length and do it right once. You are deciding on head gasket because of chamber size instead of the other way around. It's the correct combination of parts and assembly that make some guys make good power and go FAST.
Old Mar 12, 2008 | 04:24 PM
bww3588's Avatar
anyone on my question?
Old Mar 14, 2008 | 04:01 AM
PREDATOR-Z's Avatar
Originally Posted by bww3588
im running the same setup, with the exception of 1. MS4 and 2. GM MLS gaskets. same heads same chamber size. also i am cutting the pistons, (obviously), am i going to be in DCR danger? i dont want to risk my motor.
Not even close to danger
Old Mar 14, 2008 | 04:06 AM
bww3588's Avatar
awesome thanks PZ
