Mistake installing valvesprings.....help!
Old Mar 12, 2008 | 09:00 PM
T/AWS666's Avatar
Default Mistake installing valvesprings.....help!
Ok while i was just finishing up my first cam swap. i was following ls1howto's guide on installing the valve seals onto the valve (patriot golds). it said to use a 10mm or 12mm socket and a hammer to seat the seal to the valve. i grabbed a 10mm and said this fits. but after a did a few i realized that the top metal ring on the seal was bending. i then realized a 12mm seats it w/o breaking the metal.
This is obviously somthing i need to go back and fix but...
My question is:
what effects with it have on my motor the way it is?
and can i start the car up and make sure everything else is ok and go back and change the seals later, or should i not start the car with the seals in this condition?
thanks in advance
Old Mar 12, 2008 | 09:11 PM
andrew69_04's Avatar
If your right there you should cahnge them. Y put it together and have problems in a few 1000miles and tear it al back apart again. do it right and do it once.
Old Mar 12, 2008 | 09:15 PM
T/AWS666's Avatar
i know thats what i am probly goign to do.
anyone know what the effects of this would be, if i did start the car?
Old Mar 12, 2008 | 09:29 PM
RE AND CHERYL's Avatar
Bad intake seals will cause the motor to suck oil past the seals and bad exhaust seals can cause almost nothing aside from a little oil getting into the exhaust.
Re'
Old Mar 12, 2008 | 09:35 PM
joker machine's Avatar
You could burn oil(do to valve seals leaking)
Old Mar 13, 2008 | 02:52 AM
2000Hawk's Avatar
I agree change it while its already apart, save yourself the hassle. Maybe it isn't damaged enough to cause a problem, but you will sleep better at night knowing you got it right the first time.
-Joel
Old Mar 13, 2008 | 06:09 AM
T/AWS666's Avatar
i know i agree with all of you. i was really tired but wanted to finish up the valve springs last night. tired and anxious to get it together. not a good way to work. at least i know what i did wrong
thanks everyone
