JP billet single row timing set
Old Mar 14, 2008 | 08:38 AM
85Iroc's Avatar
Default JP billet single row timing set
I know the question about which timing chain is asked a lot but I'm wondering how much adjustability it has & how accurate the JP billet set is. I WILL be degreeing the cam & I don't believe the factory sprockets & LS2 chain can
be adjusted if the cam timing is off a little. I want to be ablet to adjust it a degree at a time.
Old Mar 14, 2008 | 09:38 AM
vettenuts's Avatar
This timing set had 2 degree increments on the crank sprocket (make sure you use the correct timing mark). Also, this set has a Torrington bearing on the cam gear, which in my opinion, is becoming a necessity with aftermarket valve train loads.
