driver side not firing need help
Old Mar 15, 2008 | 02:05 PM
DSRCAM's Avatar
Default driver side not firing need help
ok my driver side is not firing. i pulled three plugs and they re all clean but on passenger side. all blck any input on this.. i even cheked the ground but nothing..
Old Mar 16, 2008 | 12:25 AM
tazinhawaii's Avatar
I've had a similiar problem before. Check all of your fuses. There is one fuse that goes to the drivers side coil packs. I got some wires wrapped arounf the steering column which caused a ground that blew a fuse and lost the drivers side coil packs. This is obviously just one possibility.
Derrick
