Throttle Body hook up Question
Old Mar 17, 2008 | 05:29 PM
dondb's Avatar
Default Throttle Body hook up Question
Just bought a 02 Camaro LE and just had TB ported. When i was puting the TB back on the car I noticed two areas for wire hook ups - one for the butterfly where the cable fits into a sort of rocker-then on the side of the rocker is another place for a wire-there is no wire to hook up here? I looked at other LS1 engine pictures and see the cable I have missing on the side. Can anyone help me in maybe why I don't have one-or if i should have one???
Thank You in advance for anyones help.
Old Mar 17, 2008 | 06:21 PM
spikely23's Avatar
i believe you are talking about the gas pedal cable and the other one should be the cruise control. i hope that helps
Old Mar 17, 2008 | 07:11 PM
FMX05's Avatar
Yeah it sounds like your missing the cruise control cable to me.
Old Mar 17, 2008 | 07:14 PM
dondb's Avatar
Thanks-that must be it. Must of been taken off, I have the original msrp and cruise control is on the sheet.
Old Mar 17, 2008 | 08:54 PM
sroach20's Avatar
some cars like mine only have one. look in front of your battery and see if you have the tcs module right in the way. there are two cables going to it and one coming out going to your tb.
Old Mar 17, 2008 | 10:43 PM
robdawg13's Avatar
I believe Traction control cars had only one cable and cruise control cars w/out Traction control had two
