What is that noise?
Old Mar 26, 2008 | 06:56 PM
Camaro396's Avatar
Id definatly say header leak. Sounds exactly like mine did when my headers came loose. I was flipping out and my dad was like chill the **** out its just the headers, so I tired and sure enough the back two bolts were loose. Tightened them up and problem solved. As long as your oil pressure is the same and everything Id guess headers. Grab a 10mm and try them at least, it only takes 5 seconds....
Old Apr 3, 2008 | 11:23 PM
MIDNITE Z's Avatar
Thanks....I'll have to check it out
Old Apr 3, 2008 | 11:45 PM
MIDNITE Z's Avatar
Could it be the bearings...I noticed the car is low on oil
Old Apr 15, 2008 | 11:30 PM
MIDNITE Z's Avatar
UPDATE
I found out that I have an exhaust leak and I need a new header gaskets (passenger side)
