02 LS6 springs in an 01 FBody?
216 / 220 .525 / .532 114 LSA
212 / 218 .522 / .529 114 LSA
Would the '02 LS6 springs work okay with these cams? Also, do the spring seats need to be changed with the '02 LS6 springs? When I did a search, someone mentioned that you need the '02 seats to get the installed height correct. The rev limiter is going to stay stock, at least for now. I really won't get much by raising it with these cams anyway. The reason I'm thinking about going with the LS6 springs is to keep the valvetrain noise down.
Thanks!
<strong> The 02 springs would work with that cam just fine. And no you dont need 02 valve seats. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You might want to use the 01 LS6 spring seats, or the 02 LS1 valve guide seal/spring seat combination. They are thicker than the 98-01 LS1 spring seat and will correctly set the installed height. 02 LS6 engines use the same seal/seat that the 02 LS1's use.
