Big Cam=Poor choice= poor result.
Old Mar 21, 2008 | 08:18 AM
  #41
R32WA's Avatar
Im not real bothered with its HP output more its bucking down low and driveability. After 2000rpm its smooth sailing. So far it seems the only way to lose the surging and pick up the low down is to fit a smaller cam. the dip around 3500-4000 isnt even noticeable on the road.
Old Mar 21, 2008 | 08:27 AM
  #42
LS1-450's Avatar
The concern isn't that the dip isn't noticable. The concern is whether or not the dip is caused by a lean condition in the A/F mix during wide open throttle. If this is the case, your engine will like it much less than you do. Those type of dips are often caused by the knock sensors pulling timing due to a lean A/F mix. If it were my engine, I'd surely want it evaluated + there's the benefit of more "under the curve" power.
Old Mar 21, 2008 | 08:35 AM
  #43
1BadAction's Avatar
sounds like a cam timing issue to me...
Old Mar 21, 2008 | 08:40 AM
  #44
R32WA's Avatar
The cam is ground on 110+4 , I wonder if retarding it will make a difference? maybe dropping the 4 degrees bring it back to 0? depending on what it will do to my SCR/DCR.
Old Mar 21, 2008 | 09:35 AM
  #45
PREDATOR-Z's Avatar
You say it is a dog down low, retarding the cam will not do anything but make that worse.
Did you degree the cam in your motor?
Your issues are purely tuning unless you have a mechanical issue, like intake leak, sticky TB sensor, faulty cam sensor etc...
Old Mar 21, 2008 | 09:46 AM
  #46
R32WA's Avatar
Everything seems fine theres no codes, no audible vacuum leaks all the gaskets etc are all brand new and torqued down to specs.
Old Mar 21, 2008 | 09:48 AM
  #47
socmguy's Avatar
Restricted User
get an adjustable timing set and adjust it so that it's tuner friendly.
Old Mar 21, 2008 | 09:51 AM
  #48
R32WA's Avatar
Its got an adjustable set , but just what do I adjust it to? I have sent a request off to Patrick G to have a new more street friendly cam spec'd up, I think I was a bit over zealous in going for a cam of this size.
Old Mar 21, 2008 | 10:17 AM
  #49
Azrael's Avatar
I think it can be done with your current cam though, since we are running a very similar cam in our 346 and did 440rwhp on a Dynojet through a stalled A4 on a Nitrous tune. Your 383 should have an easier time than our stock stroke car...
Although I am curious how this turns out for you!
Old Mar 21, 2008 | 11:00 AM
  #50
Soul TKR's Avatar
R32WA, that doesn't sound right at all... not sure what your issue is, but just to compare...
I've got a 364c.i., with a 224/224 .581 114lsa cam, and AFR 205cc heads, BBK LT's, BBK ORY, BBK IM, BBK TB...
this was also tuned on a Dyno Dynamics and I made 446rwhp/416rwtq
Old Mar 21, 2008 | 01:32 PM
  #51
1BadAction's Avatar
predator is right...
I think you need to open it up and make SURE the cam is timed correctly with a degree wheel. then go through everything else in the valvetrain with a fine tooth comb.
who assembled your engine and who ground the cam for you?
Old Apr 10, 2008 | 09:36 PM
  #52
SS Enforcer's Avatar
Dan the tuner would have given you good advice regarding your car so what did he say ?
Who did the motor ?
cheers
Old Apr 10, 2008 | 10:00 PM
  #53
airflowdevelop's Avatar
It's not the cam... And I would be curious of your super dooper aussie tuner. Not to throw stones...but things are different on the south side of the planet.
I just finished a 264/270 @ .050 - .714/.744 108 ICL / 112 LS cam combo for a school teacher. This is on a 346" shortblock with very big heads. I can't get him to stop driving it!!!
Get someone to tune it properly! Or find the vac. leak!
Old Apr 10, 2008 | 10:07 PM
  #54
allngn_c5's Avatar
I believe he is running on 7 cylinders, not all 8. Did you forget to connect a wire ?
Old Apr 10, 2008 | 10:46 PM
  #55
drz's Avatar
drz
I concur, I bet it's running on 7. I put a motor together not long ago, a budget 346 with a lazy-lobe 240/244-110+2 and it idles fine, lopey, but with little rocking, and it pulls fine from well below 2000rpm without surging. Made nearly 500rw, too. And that's a 346! A properly running 383 WILL behave more mildly with a similar cam.
Just the bit where he said it rocks around badly when idling to me is the most profound evidence - a 383 with that cam should have a mild lope, but it should NOT shake badly. If it shakes as badly as he claims, it's either idling at 500rpm or it's down a cylinder!
Old Apr 10, 2008 | 10:55 PM
  #56
allngn_c5's Avatar
Thanks for the backup. Maybe he'll go check.
Old Apr 11, 2008 | 12:08 AM
  #57
01slowbird's Avatar
in the tune man
Old Apr 11, 2008 | 01:08 AM
  #58
358chevycamaro's Avatar
Man I am running a motor almost identical to yours in every way except it is 347 cubic inches. My cam is very similar as far as duration it is 239/242 spec'd out and ground by Allan Futral. Mine runs and drives great. Heres what you need to do before WASTING money on a new cam...
-Degree your cam and get that bastard set right (because I would bet money that it isn't!)
-If that doesn't help go over your valvetrain with a fine tooth comb and your ignition system
-If that doesn't resolve the issue FIND A NEW TUNER!
Old Apr 11, 2008 | 02:14 AM
  #59
gold98Z28's Avatar
if you can show me an unported fast 90 dyno without that 3500ish tq dip i will suck you off, its not one of his issue's. ive seen it on every unported fast 90 and more so on bigger cube cars.
Old Apr 11, 2008 | 06:36 AM
  #60
blu1's Avatar
Originally Posted by brad8266
Ive had my car on both a dyno dynamics and a dyno jet and got the exact same hp numbers, its the mustang dyno that reads lower.
Well an uncorrected correction factor DD dyno will read just like a Mustang dyno and possibly a little less. The thing with a dyno dynamics is you can adjust the % correction factor to inflate the owners heads to avoid threads like these.
See this thread for a prime example:
https://ls1tech.com/forums/showthrea...824&highlight=
I've had my car on a DD and it made more than it did on a dynoject, BUT the shop already had some crazy +14% figure added to it to make it "READ" like local dynojets.
