what`s needed for ls7 conversion
Old Mar 20, 2008 | 11:11 AM
Bader-X's Avatar
Default what`s needed for ls7 conversion
Hello
I found a good deal on an ls7 engine that`s still in the car locally intake to pan and I have a 98 Z28so here are my Q`s if you can help it will help others to thanks in advance ^_^
1-can I re-use my accesories(amp,p/s,water,a/c,idler)?
a:
2-will I have to use the dry sump oil system or I can bolt my pan and oil pump?
a:
3-what`s the adapters needed for using the ls7 fuel ejectors and coils and sensors?
a:
and finally what else other than ordering a cable 90mm TB conversion?
Old Mar 20, 2008 | 11:42 AM
LS6_Silverado's Avatar
The reluctor wheel is 58x instead of 24x so you will have to change that out. You will also need a camshaft sensor adapter because im pretty sure is was moved from the back to the front on genIV engines.
Old Mar 25, 2008 | 06:34 PM
Bader-X's Avatar
thanks for answering Q #3 what about 1 & 2?
Old Mar 25, 2008 | 07:57 PM
Suaveat69's Avatar
Might want to ask jason @ Katech. They did an LS7 swap into an F Body. I am sure he would know.
Old Apr 21, 2008 | 05:40 PM
sdbrown84's Avatar
Having an LS7 built now.
You can use a wet sump like stock. Same oil pan, just will need a hole drilled on your block for the dipstick.
Builder says the stock pulley, idler, ac, waterpump are all re-usable.
New relutor wheel (ie cannot use stock LS7 crank as is) will be needed. Conversion harnesses for your fuel lines, knock sensors, and crank sensors are available from sponsors. I believe they will run $250.
