No oil pressure after h/c install...help please
we cranked it over with the coils unplugged and then started it up...waited a few seconds and the oil gauge didn't move...tried again and it still didn't move. the engine sounds fine..do you think its the oil sending unit?
Agreed ^^^ if the sending unit is plugged in I would suspect the o-ring. How did you install the o-ring? There is a lip for the o-ring to sit on, if you pressed it down too far you will not have pressure.
