Rod bolt resize ARP Katech
1. Arp bolts are a bolt in replacement.
2. Arp bolts don't mess up good rods.
3. Arp misleads its customers by saying "in their instructions "always resize your rods when you can't perform this procedure on a cracked rod. What they should say is, make sure your rods are within specs when installing new rod bolts.
4. katech rod bolts have more realistic install instructions.
5. If your rods are out of round, Katech nor Arp rod bolts will save your engine!
I am an Ase master technician with a firm understanding of engine repair , but even I can make mistakes. If you feel my guide has an error. Please post up.
Step 1: Install aftermarket rod bolts and assemble rod without bearings.
Step 2: Hone housing bore .002" giving you a new "low" of 2.2267".
Step 3: Check bearing clearance with oversize bearing, such as Clevite's 1776-P made specifically for resized cracked cap rods.
*Note this is even done for Ford's mod motors as well.
Me personally, I wouldn't do it. I'd rather spend the money and do it right rather than take the chance because if something happens, you may spend that money anyways at a time you don't expect it, and probably have to spend more to replace parts that may have damaged. All for what? To turn a few more RPM in your cam only streetcar/daily driver? No thanks!
