tfs heads which cam
Old Mar 22, 2008 | 08:45 PM
speedyblue's Avatar
Smile tfs heads which cam
im going to buy the trick flow 215s when my tax money comes back and was wondering if i should keep the cam i got or buy the t-rex cam . Right now i have thunder racings trak cam and really like it. the specs are 231 234@.050 640int 590ex duration. Would there be a big power difference between the heads. My nova is mostly used on the track and runs 7.40s in the 1/8th weighs 2700lbs all stock motor except cam and headers. I also run a 3500 stall. any suggestions will be appreciated. I want to get my car in th 6s on motor and then spray a 150 max. thanks
Old Mar 23, 2008 | 06:57 AM
BlackScreaminMachine's Avatar
Internet Mechanic
SOunds like you run only 1/8 mile. I would get something that uses the "under the curve" power better, but with n2o its a artifical atmosphere so that may not matter that the trex is primarily a top end cam
Old Mar 23, 2008 | 10:04 AM
speedyblue's Avatar
yeah i would like to keep the trak cam, but ive heard awesome things about the trex. the trak cam is also hard on valve springs because of its extreme ramp.
i havnt seen anyone using the trex with the trickflow heads yet, alot of people are using the vindicator cam.
Old Mar 23, 2008 | 12:34 PM
ssfast99's Avatar
i will be as soon as i can afford the heads, i love my t-rex but last night i started up a friends new setup with a ls3 and trak cam and it sounded good. i can vouch that the t-rex is a top end cam by far. 1/8 mile you might want to keep with the cam you have and just change springs every season.
Old Mar 23, 2008 | 07:13 PM
RAGENZ28's Avatar
You'll need more converter to get it to run better on the motor, with a trex cam it will leave even worse on the motor unless you add more stall.
Old Mar 23, 2008 | 07:58 PM
Internet Mechanic
That, and/or gearing.
Old Mar 23, 2008 | 08:31 PM
speedyblue's Avatar
i wanted the tighter stall because i plan on spraying the car out of the hole. i might be selling the trak cam soon ,as i hear it is harsh on springs. it has less than 20 passes on it.
