Replacing trans fluid
Old Mar 24, 2008 | 10:50 AM
SSstud's Avatar
Default Replacing trans fluid
ok so i installed the b&m shift kit.everyone seems skeptical but ill let you know soon enough i hope...but the problem is now i cant figure out how to replace the trans fluid...i was told to remove the center council and the shifter but i cant figure this out..anyone have any suggestions?
Old Mar 24, 2008 | 02:29 PM
omcar's Avatar
to replace the trans fluid you need to drop the pan very carefully, usually letting one corner hang down so as not to get the fluid all over and at the same time I suggest that you replace the filter as well..
Old Mar 24, 2008 | 03:05 PM
2000KnightRider's Avatar
x2 Drop the pan
Old Mar 24, 2008 | 03:14 PM
massls1guy's Avatar
You installed a shift kit so that means all the fluid is out, the pan has been off and is probably back on. Now are you asking how to pour the fluid back into the transmission?
The fill tube should be near the firewall in the engine bay. If you have an owners manual it has this kind of info. Good luck.
