Hellfire rings on Manley pistons OK
Old Mar 24, 2008 | 04:16 PM
LS1NOVA's Avatar
Default Hellfire rings on Manley pistons OK
I would like to use hellfires on these pistons. Does anyone know for sure if the ring grooves are the same base diameter? Thanks
Old Mar 24, 2008 | 04:35 PM
JPH's Avatar
JPH
whatever the ring groove sizes are in the piston, just order the correct rings for the BORE SIZE, RING GROOVE SIZE, OIL RING TENSION.
Old Mar 24, 2008 | 05:23 PM
LS1NOVA's Avatar
I know that, but on the Manley box it says to use only Manley rings due to the inner machining of the ring groove may be different from other manufacturers.
