50W Bad for pump??
Old Mar 24, 2008 | 06:31 PM
MusTangKilla01Z28's Avatar
Default 50W Bad for pump??
Just herd from someone who runs 50W motor oil in his 2000TA that i should do the same.... do you think i should or is this bad for your oil pump?
Old Mar 24, 2008 | 06:40 PM
99.9percenter's Avatar
WARNING!! WARNING!! WARNING!! DANGER! DANGER! DANGER! PLEASE do NOT NOT NO! NO! NO! This will kill your motor The oil pump will be fine, but your bearings can not live with 50wt. 50wt is for motors set up with loose clearances.
Old Mar 24, 2008 | 06:55 PM
BLACK2001SS's Avatar
yEP wHAT hE sAID.
5w 30 is the norm the the W in 5W stands for winter the 30 is the weight which the car is designed for.
Old Mar 24, 2008 | 07:00 PM
joker machine's Avatar
The only time you really need to use 50w is if you are running alot of boost and no2. Thats because your piston ring gap will big this will make you burn oil and the 50w might not burn off as fast. I run Amsoil 0-30,I never burn oil.
