Valve to piston Check????
Old Mar 25, 2008 | 05:05 PM
fastvet's Avatar
Default Valve to piston Check????
I am putting on a new set of heads to a new cam and need to know how to check valve to piston clearance? If anyone knows, please chime in. I really dont want to mess up these new valves. Thanks guys!
Old Mar 25, 2008 | 07:05 PM
brad8266's Avatar
Use the clay method or the checker spring and dial indicator method. Google "piston to valve clearance" and you will find out how to do it.
Old Mar 26, 2008 | 08:27 AM
fastvet's Avatar
Anyone else
Old Mar 26, 2008 | 08:31 AM
LS1Z28_98's Avatar
Brad hit it on the head. If you are looking for an equation to figure it out, there isnt one, too many variables for a consistant equation. I just got educated in this matter. The clay is the way to go.
Old Mar 26, 2008 | 09:17 AM
jshelton2006's Avatar
clay is probably best, but if you're just wanting to see if you have a certain amount of clearance, you can put feeler gauges of that thickness between rocker tip and valve...that won't tell you exactly how much you have tho.
Old Mar 26, 2008 | 12:46 PM
GuitsBoy's Avatar
Use a dial gauge and a test spring, and measure in 2* increments from 15* BTDC to 15* ATDC
Old Mar 26, 2008 | 03:06 PM
vettenuts's Avatar
That's what I do and then I plan to double check everything with clay.
Old Mar 31, 2008 | 07:03 PM
Bill Bowling's Avatar
Where are you getting your clay? I have not been able to find any around here yet.
Thanks,
Bill
