please help knocking noise
Old Mar 26, 2008 | 08:15 PM
04BlackSSS2's Avatar
Default please help knocking noise
my friend has a 2000 camaro ss auto with 26k miles. we were just driving around raced a little japper snapper, pulled into the gas station after, and on the way home we heard a knocking noise. we got out of the car opened the hood while idling it was knocking. do you guys have any idea what it can be. can it be a broken connecting rod. he doesn’t remember what his oil pressure was at before but it think it is supposed to be at like 40 at idle. now its like 15-20.:confused :
Old Mar 27, 2008 | 05:49 AM
No ideas, guys
Old Mar 27, 2008 | 06:02 AM
Deeavi's Avatar
Could be a rod bearing? Probably need to tear it down and check it out before it self destructs. Stuff happens!
Old Mar 27, 2008 | 08:10 AM
slowmofo's Avatar
low oil pressure is a real bad sign
Old Mar 27, 2008 | 08:49 AM
LT-4Play's Avatar
Do a compression test to find out if it's in a cylinder(s). If the compression test comes out o.k. then it's more than likely on the bottom end.
