LS1 power capabilities
Old Mar 31, 2008 | 03:16 PM
deuce_454's Avatar
priced the92mm setup?? its 1200 bucks and so are the heads... so for 2500 bucks its yours,, ill even throw in an LS6 intake and ls6 TB no charge... the turbo will deliver 850 Hp and not break a sweat.. should come on at 2000 rpm... all components are matched,
Old Mar 31, 2008 | 05:01 PM
Red98C5's Avatar
I have two buddies with C-5's that are using the APS twin turbos. Last week, on 17" M/T drag radials the one car ran 9.94 @ 139 (with back up runs and driving to and from the track) the second car did not run but last time went 10.04 @ 138. The 9 sec car has an A4 with 3.15 gears and the second car has an A4 with 3.42 gears, and both run on pump gas, and have the OEM LS-1 heads (not 243's). Also both are using the GM cams, not aftermarket!
