V6 turned V8
Old Mar 28, 2008 | 06:33 PM
Ls1 Blue Bird's Avatar
Default V6 turned V8
Does it take alot of work to switch a v6 for an 8 (LS1). im looking into buying this cheap 98 camero automatic v6 and later on, like in a year drop in my old motor witch was an Ls1 into it. It shouldnt matter if my engine had a manual trany right because its just the engine being switched. Would you have to buy extra parts for the switch?
Old Mar 28, 2008 | 06:38 PM
mvvette97's Avatar
Not an easy swap, just a few things would be engine mounts, all wiring, pcm, and the list would go on and on. Also some V6 cars just have the rear drum brakes depending on year so that wouldn't be the best for stopping. I think if it was me I would buy an LS car. It will save you alot of work and anger, you will thank yourself later
Old Mar 28, 2008 | 09:29 PM
Marc 85Z28's Avatar
Forget about the engine swap. You can't even spell Camaro right.
Old Mar 28, 2008 | 10:44 PM
mvvette97's Avatar
was that really needed?
Old Mar 29, 2008 | 07:23 PM
keliente's Avatar
You would need a flexplate.
With LS1 cars being as cheap as they are...I personally would not mess around with swapping a V8 into a V6 car.
Old Mar 30, 2008 | 02:22 AM
kingsey's Avatar
Just buy a ls1 car. Not worth the hassle dude
Old Mar 30, 2008 | 11:57 AM
dreamls1's Avatar
I am sick of people saying buy ls1 car. If you want to do the swap go for it, I did. Its really not that bad. If you find a donor car it make thing so much more easy. Good luck which ever way you go.
