heads with a cam
Old Mar 30, 2008 | 09:12 PM
fox16's Avatar
Default heads with a cam
what heads to go with i really dont have the money for sum afr's or sum trickflows.....but i was wondering would sum p&p 243's or sum p&p 5.3 be alright and what would u go with? the car is a 04 gto with a hpe megadeath cam with the usuall bolt ons
Old Mar 30, 2008 | 10:40 PM
eamador11's Avatar
TSP has some budget heads you can consider.
Old Mar 31, 2008 | 12:21 AM
Zcleanest28's Avatar
What are the specs on that cam? Money not a problem? Trickflow 215s or AFR 205s flow very well. PRC 5.3s are reasonably priced as are patriot performance 243s. Just make sure you build your heads around the cam you already have, unless you change it out. There is such thing as a best head for every cam.
Old Apr 1, 2008 | 12:15 PM
fox16's Avatar
242 244 610 612 112lsa so what would the best head be for that cam out of the 5.3 or the 243?
Old Apr 1, 2008 | 12:20 PM
03Sssnake's Avatar
243s ported with a cam that size.
Old Apr 1, 2008 | 08:17 PM
fox16's Avatar
thanks i for ur info!!!!!
