Anyone transfer balance wt to U/D pulley?
Old Apr 2, 2008 | 09:49 AM
2gofast's Avatar
Default Anyone transfer balance wt to U/D pulley?
I am going to be installing a powerbond U/D pulley. I was reading the GM shop manual for my 2004 corvette and it talks about the possibiilty that a balance weight was added to my harmonic balancer when the rotating assembly was balanced. THe manual indicates that I need to put the same weight in the same relative position on the replacement harmonic balancer (does not mention a u/d pulley replacement).
Just wondering if anyone else bothers to do this. I am planning on doing it but if no one else does and it does not cause a problem then I might skip it. I don't know for sure that I have a balance weight on the factory pulley.
So, what is everyone doing?
Thanks
2GOFAST
Old Apr 2, 2008 | 11:19 AM
SOMbitch's Avatar
Never seen one. Our engines are internally balanced. Weird?
Old Apr 2, 2008 | 11:35 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Your fine, there is no need to add any weight. Look at the stock pulley. I looked at mine, no weights.
