shaft rockers
Old Apr 2, 2008 | 09:04 PM
Apollo0526's Avatar
Default shaft rockers
will they fit under the stock valve covers?
Old Apr 2, 2008 | 09:16 PM
DONAIMIAN's Avatar
what brand?
Old Apr 2, 2008 | 09:18 PM
DONAIMIAN's Avatar
Although shaft rockers should not designed around stock covers. If you have the money go jessel.
Old Apr 3, 2008 | 07:33 AM
KCS's Avatar
KCS
Moderator
I have heard that the shaft rockers that are designed to fit under stock valve covers (T&D specifically) have some design flaws in them which limits the lift you can use without running into problems. Erik (Racer 7088) has had some experience with these rockers. Find his name in the member's list and check his recent posts, you'll see what I mean.
Old Apr 3, 2008 | 08:28 AM
Apollo0526's Avatar
thanks
