bang and smoke, help?
Old Apr 3, 2008 | 08:34 PM
joey142501's Avatar
Default bang and smoke, help?
Hey, im a buildin up my z28 i have put ported ls6 heads, 114 cams, typhoon intake, and now im needing some help i done every thing by the books and im in trouble now
i went to start her up for the first time and bang and smoke coming ouut the intake what needs to be done? help
Old Apr 3, 2008 | 08:51 PM
1BAD02WS6's Avatar
i think i found the problem..... our engines only need 1 cam not 114 cams
sorry that was lame. but we need more info to help. all cam specs? heads milled? did install the cam dot to dot or 180 out
Old Apr 3, 2008 | 08:52 PM
stricker76's Avatar
This is just a shot in the dark, but did you check the piston to valve clearance?
Old Apr 3, 2008 | 09:02 PM
joey142501's Avatar
it has
Thunder Racing Custom Camshaft
220/220 .551/.551 114 LSA
Patriot Performance CNC Ported 243 LS6 / LS2 2.055"/1.57" 64cc Heads Assembled
Crane Cams LS1 1.78 - 1.7 rocker kit
dots are lined up and ptv is good
Old Apr 3, 2008 | 10:09 PM
mvvette97's Avatar
just sounds like to me it just spit back. Did you try to start it after it done that?
Old Apr 3, 2008 | 11:01 PM
Gun5's Avatar
ya that cam isnt big enough to be hitting pistons check your plugs and wires again and roll her over
Old Apr 4, 2008 | 12:28 AM
MLP00Z28's Avatar
If you do not have coil rails, check you placed each one in the right position and connected them correctly
