timing chain + gear
Old Apr 5, 2008 | 08:18 PM
bjbaxter22's Avatar
Default timing chain + gear
so I have a 98 Z28 and want to know if the timing chain or timing gear breaks, will the piston go up and hit the lowered valve? Also, I heard that some engines come with a plastic timing gear, do the ls1's? Thanks for your time!
-Brian
Old Apr 5, 2008 | 08:36 PM
THE RED "BLUR"-408's Avatar
Warning: Bad Trader
yea you will have valve slap if that breaks cause your timing will go out and your cam will just go ever which way and bend valves
Old Apr 6, 2008 | 12:59 PM
ChrisH821's Avatar
No, the timing gear is not plastic.
