which cam with low end power from 2k to 6k?
Old Apr 8, 2008 | 08:43 AM
omcar's Avatar
Default which cam with low end power from 2k to 6k?
I want the tranny to shift at 6,200 max..which cam only set-up will give me 4 tenths with long tubes and a tune? This is mostly a bracket car.
Thanks
Old Apr 8, 2008 | 08:57 AM
Patrick G's Avatar
LS1 Tech Administrator
224/224 110LSA +4 advance
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Apr 8, 2008 | 09:10 AM
landonew's Avatar
Is this the optimal torque cam? I was of the opinion that the low duration 224/224 cams where old school, and that you could achieve the same results on low end power w/ a cam that is high 220s low 230s, but achieve better top end power.
I guess this was is untrue though since every cam makes power at ONE optimal RPM. So i guess the smaller the cam, the better the low end torque. Of course, I don't think people loose low end torque when they go with an aftermarket cam which is obviouse larger than stock.
Old Apr 8, 2008 | 09:29 AM
omcar's Avatar
Patrick, since I'm looking for low to mid-range power this cam sounds about right.. should I use beehive double springs and stock everything else, ie. pushrods and rockers?
Thanks
Old Apr 8, 2008 | 09:38 AM
Patrick G's Avatar
Thanks
I did not list lift because your springs will determine how aggressive you can go on cam lobes.
For 918 beehive springs I would go 224/224 .568/.568 110LSA +4 with Comp XE lobes and 7.400" pushrods.
For Patriot Extreme dual valve springs I would go 224/224 .609/.600 110LSA +4 with Comp XFI lobes and 7.425" pushrods (to account for the smaller base circle of the cam).
Stock rockers are fine with either cam.
__________________
Old Apr 8, 2008 | 01:57 PM
omcar's Avatar
Thanks for the info..
Old Apr 8, 2008 | 03:27 PM
AU N EGL's Avatar
Like the look of that cam.
Old Apr 8, 2008 | 03:33 PM
King Nothing's Avatar
tr230 i've been told is great between 2k and 6k i'll find this out hopefully soon since mine is sittin in my room
Old Apr 8, 2008 | 03:42 PM
TXZ28LS1's Avatar
i always thought it was tough to beat the 224/224 cam down low!! but im running an MTI X1 230/227.
Old Apr 8, 2008 | 04:32 PM
VIPERBLUELX's Avatar
X1 here as well
Old Apr 8, 2008 | 07:19 PM
Hell'sChariot's Avatar
I currently have a tr224 112 and I have 300ftlbs or more @ 2500rpm. Its an awesome cam. But I ordered a tr230 111 cuz I wanted alittle more powa.
Old Apr 8, 2008 | 07:38 PM
CAMAROZ28AQUINO's Avatar
