5.3 Cam
Old Apr 8, 2008 | 11:22 PM
LS10blazer's Avatar
Default 5.3 Cam
Ok i just got a 5.3 with 28,000 miles that im putting in my 85 s10 blazer.what cam would be good for this setup.im going carburated with a vic jr the blazer already has a 3.73 gear 8.5 rear and im using a th350 trans with a 3000 stall.with the heads that are on it and and with the carb i want it to be as quik as my old setup.witch was a 355 ,rpm heads same trans and converter.it went 7.90s on motor and 7.20s on a 150 shot.thanks for any help.joey
Old Apr 8, 2008 | 11:30 PM
96lt1m6's Avatar
look up top where it says "performance trucks" click that and you will see a bunch of set ups a what the truck world raves about it is a bit different than car set ups.
