Noob cam question?
Old Apr 9, 2008 | 01:34 AM
import810's Avatar
Default Noob cam question?
Well I'm slowly moving over from hondas to chevys or well it seems. I just aquired a motor for my 1990 rx7. I picked up a 2002 ls1 and t56 out of a totaled camaro and I'm trying to figure out what has been done to the motor.
Here is what I can see:
Stock LS6 intake manifold
Stock throttle body
AFR heads #1510
back of cam says:
3725r | 3725r
HR 113
271440
L6550-07
If anyone can give me any info on how to find out what kind of cam that is, it would be great. I got a pretty good deal on everything but it needs some little things here and there. And the longtubes that were with it were crushed in the wreck
Also if someone can find out the cam any1 guess what kinda numbers this thing will put down?
Old Apr 21, 2009 | 06:17 PM
import810's Avatar
up any1 know anything what these numbers on the cam mean? any way to find out the specs?
Old Apr 21, 2009 | 07:18 PM
goober35's Avatar
call afr on the heads. They will be able to tell you which ones they are. But they are a $2k set of heads.
Just keep plugging away some one will know witch cam that is.
Old Apr 25, 2009 | 06:22 PM
import810's Avatar
I know about the heads, but the cam is what I'm stuck on. I took the heads off for an inspections and they are all good but as to what type of cam it is idk?
Old Apr 25, 2009 | 11:02 PM
JDishong's Avatar
Comp cam: 230-230* @.050
.592 lift.
