Pushrod help
Old Apr 9, 2008 | 05:17 PM
trey04gto's Avatar
Default Pushrod help
I have a VERY LOUD valvetrain. I am using the stock pushrods and think it could be the cause. I know I need a length checker but wanted to throw my setup out and get some guesses on length I should order.
Iron 370ci
317 heads stg 2.5 by TEA, milled .010"
224/232 .585/.595 114 lsa
harland sharp rockers and caddy lifters
also this is a procharged car and after 6600rpm seems to fall on its face....
Old Apr 9, 2008 | 10:46 PM
trey04gto's Avatar
Come on fella's....... The International brotherhood of teamsters
Old Apr 10, 2008 | 12:49 AM
2000KnightRider's Avatar
Your pushrods might be too short, that and you need hardened pushrods as well.
Old Apr 10, 2008 | 08:39 AM
trey04gto's Avatar
I bet you are right!!! Others...
Old Apr 11, 2008 | 07:26 PM
Shawn MacAnanny's Avatar
well pushrod length checkers are only like $24 i would definately buy one. There is a very good posibility that they are too short. Too short means not enough lifter preload which means a harder hit on the lifter with the pushrod, less valve opening, and poor top end from low lift. I'd assume it would be like retarding the cam a couple degrees due to the delay in pushrod action.
